I went for a drive today to see what kind of numbers I'm getting with the UG. When the car was fully warmed up, I hit full throttle in 5th gear starting at 1,200 RPM. Both O2 sensors went to 0.915 V and stayed there for a few seconds. Then the second O2 sensor went up to 0.920 and the first O2 sensor dropped right down after that in what I figure was an attempt to bring the reading of #2 O2 back to 0.915 V. When O2 #2 went back to 0.915, they both stayed steady at 0.915 again.
This suggests to me that even though I was WOT, the ECU is using its MAP (ECU table) to maintain a constant voltage on both O2's and may well be in closed loop all the time. Perhaps the UG is waiting for a switching point in and out of closed loop and we don't have one,... It's always closed. ???
The UG is reading our cars with the 9141 protocol which they say is very inefficient and out dated My refresh rate is 0.9 seconds (after using the "optimizer") so perhaps that is what the cached data is about. As long as I can hold my throttle down for more than 0.9 seconds I feel I can get an accurate reading, just with bad resolution.
From UG manual:
Fuel Trim Gauge:
Fuel trim refers to the fine tune control of fuel delivery and specifically indicates adjustments made dynamically to the base fuel
table to obtain the proper ratio of fuel to air. The fuel-to-air ratio is adjusted by increasing or decreasing the time fuel injectors
are open. Note that fuel injectors are either fully open or fully closed - there is no variable opening.
Fuel trim is generally calculated by using a wide set of data values, including forward O2 sensors, intake air
temperature/pressure or air mass sensor, barometric pressure, humidity, engine coolant temp, anti-knock sensors, engine load,
throttle position , and battery voltage.
Short term fuel trim refers to adjustments being made in response to temporary short term conditions.
Long term fuel trim is used to compensate for issues that seem to be present over a much longer period or that are essentially
permanent. Long term fuel trim generally should not exceed +- 10% in most vehicles.
Fuel trims are expressed in percentages with a range of -100% to 99.2% of nominal. Positive values indicate a lean condition
exists and the injector is left open longer to compensate, thus adding more fuel. Negative values indicate a rich condition exists
and the injectors are closed more quickly thus reducing the amount of fuel.
Example: A value of 5.0% indicates that the injector is being left open 5% longer than normal, thus the fuel to air ratio is being
increased.
Fuel trim could more appropriately be called “Injection on-time %”.
Fuel trim banks refer to the cylinder banks in a V style engine. Cylinder #1 is always in bank 1. Even though the engine may
contain two physical banks, only a single bank may be reported by the ECM. UltraGauge displays Fuel Trim Banks One and
Two if reported by the vehicle’s engine computer. For those vehicles with three or four banks, only banks one and two will be
available for display on UltraGauge.
UltraGauge supports the following Fuel Trim Gauges:
Short Term Fuel Trim percentage Bank 1
Short Term Fuel Trim percentage Bank 2
Long Term Fuel Trim percentage Bank 1
Long Term Fuel Trim percentage Bank 2
NOTE: If the engine is operating in Open Loop, the short trim will be reported as 0%.
The only time I've noticed the fuel trim being at zero was when I was coasting in gear above idle speed. I'm thinking if you've been driving for a long time with some sort of problem, the fuel trim would adjust for it then show the new settings as normal unless LTF trim shows the value compared to the base fuel table or MAP.
Mass Air Flow 2 Gauge name Range Units Abbreviation
Mass Air Flow 2 g/s 0-999.9 grams/second MA2 g/s
Mass Air Flow (MAF) is the Mass of air entering into the engine. On vehicles with actual
MAF Sensors, there will be two gauges, this gauge and Mass Air Flow 1. Mass Air Flow 1 is
the raw output from the MAF sensor, whereas Mass Air Flow Sensor 2 is the calibrated
version used by UltraGauge to calculate MPG.
The Mass Air Flow is calculated for vehicles that do not have a MAF sensor but rather use a
MAP (manifold absolute pressure) sensor. In this case, MAF is calculated by monitoring
several engine sensors, such as MAP, RPM, Vehicle Speed and others.
I'm thinking if my car had issues, these two readings would be quite different from each other as the ECU adjusts to the engine issues.
From UG manual:
Fuel Trim Gauge:
increased.
