You need to take the lighter piece out but you don't need to remove the center console to do the bushings install. To get the lighter piece out you need to pull hard on the right side, the left side comes out much more easily than the right for some reason. You also don't need to take the shifter piece out either to do it, you can leave it connected to the shifting cables to do it. Its a little trickier but it can still be done, just disconnect the ball joint parts of the shift cables then take all the bolts out. Then you just need to get the rubber bushings out, a screw driver really helps getting them out. Then after they are out just put the metal bushings underneath with the grooved side up, put a washer on top of each hole then put the bolts back in and have fun lining up the holes!
