2017 Mazda6 - Battery management system malfunction
Thanks, but that seems to be the procedure for replacing a standard battery, not one that is part of the i-ELOOP system with super capacitor.
Same goes with my Mazda, it turns out that I had a worn out drive belt that caused this error message. I immediately replaced it, and it worked fine. If you search "Battery Management System Malfunction on YOUCANIC", you will see an article that goes over common causes and possible fixes. I hope this information will be useful to others who have had a similar issue.
I thought I read somewhere that the i-ELOOP battery is a deep-cycle battery. If so, a simple AGM battery may not last long.
Hello,
This afternoon, after I started the car I got the battery management system malfunction warning. My Mazda 6 has around 86k km and it does starts ok. I know I have I-eloop and this can cause some issues including a special battery replacement.
Did anyone tried to replace successfully (without errors) the battery with a non-oem one ? I know several people were looking at AGM batteries but I couldn't find too much info.
I am assuming the dealer will ask for quite a bit of money (700$ CAD) or around for a replacement and reprogramming with an OEM battery.
Thanks
hi im from NZ & im having the exact same issue i have a mazda atenza 2013 diesel, but now my mazda wont start at all today, yesterday it started long enough for me to move the car out the way for the rest of the cars in my drive, it has a i-stop the engine lights on, it was having a bit of a lag when i was starting it now it just wont start, do i need to take it to a mechanic or can i get another battery id appreciate some advice as i bought this 2nd hand & its my 1st diesel
Funny, my battery is about to die again. I've been having the same message past couple months. Only 2 years and 6 months or so from the original battery. Dealer is asking $390 prorated for my current battery.
Decided to go with an 35-AGM battery. Planning to get the Energizer from Costco (Canada). Any other better suggestions than this ? I would probably need to get it installed by the dealer because of the programming.
