shabaka said:big props to ya
nice power for a 2.0L turbo
only bad thing is you keep getting a bigger turbo
so we can't tell what's turbocharger and what's camshafts making the power
don't mean to sound ass-y
you're making more go then i am right now
kasmankk said:very good question...
the readout from the dyno machine is in bhp. they use DASTEK dynamometers. i believe its wheel horsepower, since wheels were on the roller, unless there is a constant they multiply to get engine horsepower.
kasmankk said:the cam gears where apperrently set to slightly advance, therefore the power kicked in late. How many degree advance...ehmmmm. i have to check tomorrow. I want to cut an openning to the valve cover so that the cam gears can be set without removing the cover.
i ran at 1 bar boost max , that's about 14.5 psi.
305 bhp @ 6500
356 nm torque @ 5000 rpm
the power was going up still at rev cut (7000 rpm). I think it can go a few more ponies if i were to extend the rev cut. but i want to play safe.
Next, i'd like to shift the power band to lower RPM. The tuner told me to retard the cam gears .
Here are some dyno runs i did over the past few years.
Dyno graph on twiggy was reproduced on excel using raw data.
by the way, how do you post picture directly on this page?
Crazee D said:Thats some good news!
to insert an image, Upload the pic in your control panel and then do insert image and copy hyperlink
Any tips from the shop after that marathon install? Did they re-shim? Did they measure or record your lash measurements?
JDMSpec55 said:Do shims need to be installed with these cams? If not could this cause a 0300 code(multi missfire?)
shabaka said:buddy...come on
read the posts in this thread
(do you have a set...?)
shims have been discused to death already
Topher said:he bought my mp3 w/ these cams installed...he's new to mazda's and really doesn't have much experience with them...i couldn't answer his questions...he's just asking for help.
Crazee D said:Ok, Cool. Thanks for the heads up.
Were you having issues after the cams were installed?
from the engine?jc2904 said:i just installed my cams on the weekend... great power after 3500.... I did notice that there's a kind of perkalator sound coming from the engine.... lol
is that normal, maybe i tightened my belts to tight or is it the cams
