"TwEECer" Engine Management for Protege's
I've edited this first post since starting this thread.
My summary of the situation:
Tweecer is a product that allows tuning of the variables in the factory ECU, including, but not limited to, fuel delivery, spark timing, idle speed, rev limit. It can be set between 4 maps, and one "off" position. By using the service port on the ECU, it is completely plug and play.
The base model that allows all the tweaking currently goes for the low price of $380(wow), and the realtime model which allows realtime sensor display and datalogging goes for $550.
It currently works on a variety of ford models. After contacting Mike Glover at STKR who developed the tweecer, he is willing to have a look at the protege and see if he can make it work with our cars.
I am currently looking for someone in the Houston/Katy area to visit them so he can download the rom from our computer for research purposes.
If no one can do it, I can go, but it will take me a couple weeks before I can make the trip.
This is an amazing opportunity IMO if we can get this off the ground.
Product Info from their webpage at www.tweecer.com:
What Is The TwEECer?
The TwEECer is an adapter which connects to the J3 service port of a Ford EEC PCM, giving you the ability to substitute parameters in the calibration data with parameters that match the modifications which you have made to your engine. So as you add performance to your car, you can easily match the EEC's calibration to your combo.
How?
Using your Laptop or Desktop PC, you connect the TwEECer to the USB port and run the user interface software CalEdit, which comes with the TwEECer. CalEdit gives you a very nice and easy to use graphical user interface for making changes to your calibration. Once you have your calibration setup as you like, then write/save the binary to disk and to the TwEECer.
What features does the TwEECer have?
In addition to giving you complete control over your EEC, it has a few additional features which make it stand out above the rest.
How?
- TwEECer RT.with Real Time data logging & display along with playback capabilities. This allows you to see how the EEC sees things. This is a tremendous tool for tuning as there will be no more guessing as to what the EEC is calculating values to be.
- Four calibration locations. The TwEECer gives you the ability to flash four (4) completely independent calibrations and switch between them, all while the engine is running. An excellent feature if you want an Economy/Performance option or NA/Nitrous option. No other flashable chip/tuner on the market offers this feature. There is a 5th position which "Turns OFF" the TwEECer and returns to the stock settings, no need to waste a calibration location for a safety net. <LI class=bodytext>Graphical User Interface. The TwEECer comes with CalEdit, a very intuitive and simple to use GUI for making changes to your calibration data.
- Support Groups. There is a UBB forum setup at http://tweecer.oplnk.net where you can post, subscribe and share your EEC tuning knowledge. We have a discussion group at www.yahoogroups.com for the TwEECer owners, just send an email to tweecer-subscribe@yahoogroups.com. I also recommend that all TwEECer owners subscribe to the EEC-Tuner list at www.yahoogroups.com as there is an abundance of info there which relates to tuning.Calibration data includes:
- <LI class=blurbtext>Engine displacement <LI class=blurbtext>Injector size <LI class=blurbtext>MAF function <LI class=blurbtext>Base / Stabilized / startup fuel mixture <LI class=blurbtext>Base / Altitude / Limp mode timing tables <LI class=blurbtext>94/95 AOD-E shift points, TV Pressure, etc
- Drive & Neutral idle rpm
- Neutral & in gear rev limits
