Turpro's t-bird/vj11 upgrade
turpro
1993 mazda protege
I need to do more work but this is what's done so far. More pics and progress as time goes on. Should be installed in about a month
Spare VJ11
Unclip the wastegate
Remove the 6 8mm bolts that hold the cold side housing/wastegate onto the center section
Unbolt the 4 13mm bolts that hold the hot side to the center section
Remove these plates after removing the bolts
This is all you really need from the vj11
Bolt the vj17 center section to the vj11 hot side
Pic of it all assembled
Packed away till further notice
I still have to tap the oil feed hole to accomidate the vj11 restrictor. If someone else has a better way(using differnet fittings for the turbo and block with a ss line) let me know.
jeffscortlx from feoa made stupid power on his sohc cvh escort motor using the same hybrid turbo. im sure you will be happy with it.
Similar Threads and Articles
