boostn8 said:thanks man for your help. one more question though is there a stiffer spring out that will not change ride height? where i live i can not afford to lower the car anymore than the bodykit already does
jvohs83 said:boostn8, what are your 1/4 ET's wit the GReddy kit? I'm just gettin ready to buy one as soon as I sell some other items.
KYLiquid said:the problem with the greddy kit is not that it cant make good power (there are cars making 330whp with it) but that it makes peak power at aroun 7k rpm....and you have a 9500rpm redline......so your gearning is all screwed up for the power band the greddy kit has....
the supercharger kits I have seen can make similar power, but make it all the wya to redline....
also for a 100-105 mph trap.....that shows you have around 250 horepower at the wheel.....
trap speed isnt effected by wheel hop/bad launch like ETs are.
boostn8 said:plus if there is any sites i can go to for suspension parts to help with wheel hop? thanks
boostn8 said:i will try and find my dyno sheet but i was making 275 at the wheels. im not sure what dyno it was.
boostn8 said:eric at auto exotica or passen motorsports. same place two names. i did find my dyno sheet. it was a dynojet and i had 258 whp and 180 torque thats with running stock cat and clutch. Im getting ready to put a test pipe on and maybe upgrade to a 3 inch exhaust
