Turbo : Warm-up & cool-down procedures
CX7_Scott
CX-7 GT w/ Tech
I've seen numerous references to warming-up and cooling-down the turbo, but this being my first vehicle to HAVE a turbocharger, I have some questions.
My salesman *did* tell me to let the car idle for 15-30 seconds before shutting it off, but that's about all he said.
Can any of you take a moment to explain:
(A) What your procedure(s) is(are)...
(B) What the effect is on the components if you do or don't properly follow your regiment.
I want to make sure I do all the right things.
Thanks.
-scott
Thanks.
-scott
Turbos spin at a tremendous RPM, and relies on the oil pump to provide necessary lubricant to the bearings. Typically if you just cruised down your street at 35 miles an hour for a couple of minutes or more it is not much of an issue. But, if you just got off the highway or perhaps just climbed a tall hill, turning off the engine immediately leaves it wound up, but with out an oil feed to keep it cooled and to provide the lubrication... the effects of which could affect the lifetime of the turbo.
Whether or not it is something your should fear is debateable, esp as turbo technology has advanced. But, if you are in the habit of puttingyour foot in it every chance you get it is certainly worth the additional 30 seconds to a minute to allow the turbo to wind back down to idle speeds before shutting her down.
AH - Now I get it... (I think)
Somewhere along the line, someone mentioned that turning it off too-early also may leave oil IN the turbo which may "cook-it"... maybe they were misunderstanding it...?
If I understand correctly, it's basically to let the turbo spin-down and allow some oil to flow-through for a minute to cool it off...
So - if my commute is 40-miles and I'm doing about 70-80mph the whole way on the highway, but the last 5-minutes is 30-mph down the back roads, and the last 2-minutes is below 15mph through the company driveway and parking lot... do I still need to sit there for 30-seconds once I get to my parking spot...? SHould I just play it safe and do that...? Or is that overkill...?
Thanks...
Yup. He pretty much hit the nail on the head. Give it time before you thromp it, and give it time before you shut her down. Like someone mentioned above, a turbo timer is a very cheap alternative to waiting in your car to shut her off. They can be had for anywhere from 25-100 bucks. Some people don't mind sitting and relaxing, as others like to get on their way and let the turbo timer handle the cool down and shutting off of the car. Also, the turbo timer will automatically dictate how long the car needs to cool down by how hard you've been driving (ie: after 80mph highway driving, the turbo timer might read 2-3 minutes before turning off).
Thanks...
You're doing your cool down on the back roads as long as you aren't goosing it and driving somewhat agressively. ;)
You don't need a turbo timer unless you're boosting, then quickly stopping and turning off the car. Taking it easy 30sec before you park will be enough time for things to cool down. Waiting for the car to warm up, look at coolant temp, is also good practice.
The head mechanic at my Mazda dealer confirmed that a turbo-timer is almost 99% useless on this vehicle. Mazda knows that most of its drivers are going to get in, start it, drive it however they drive, park it and shut it off.
He says the size of the turbo is miniscule compared to performance cars pushing 1k-HP... although letting it idle for 15-60 seconds won't HURT the car... he is confident that even if you NEVER "baby" the turbo, it will last.
Knowing that... I think I will still get into the habit of letting in sit for a few seconds before killing it.
If I told my wife that she needs to idle the cx-7 for as much as 5 seconds after a stop, the car would be out the door. The head mechanic better be right....
i know... i was trying to explain my gf that.. she freaked lol... oh well i basically do almost the same as 02589 does...
If you live in an average neighborhood, with a couple of stop signs and a few turns before you get home, it should be normally cooled when you park it.
[Devil's advocate]
I live by an interstate onramp and my mother in law is in town who has a wicked lead foot.
What do I do now?
Tell her to idle the car for a few minutes waving the manual insinuating that she is a freaking maniac behind the wheel? I THINK NOT.
What's Mazda's customer care number? It'll be fun to pose that dilemma to 'em.
Seriously! What is that number? Results will be posted.
Buying a turbo timer....works great for my Evo.:)
As far as warming up....warm it up just like it also. Once the temp needle moves a little start driving slow. Once it is up to normal temp I drive normal.
Same procedure for both cars.
