Turbo Timer Question
gyrospeed
I just picked up my Apexi Turbo Timer today and was hoping of getting it put in pretty soon. Only problem is: there is no wiring diagram for the MSP so I am wondering if anyone knows which wire in the ECU is to ground and which one is for the O2 sensor? Any help/tips would be much appreciated.
Don't worry, I'm not installing it myself.
Go to the dealer and ask at the parts dept. if they can photocopy some wiring diagrams for you. In the box for the TT, there is s list of wires to hook up to, let me know if you can't find it, as I have the instructions around here somewhere. Also, I know someone who can install it for you if you want. Did you buy it locally?
Yeah I bought it from AutoFX. The reason why I need the diagrams is because the Apexi TT doesn't have wiring instructions for the MSP. It's only for Japanese cars and it only has instructions for an earlier year Familia. The set up for my TT may be different because of my alarm setup. That's why I went back to the same place that installed my alarm to see if they could hook it up but the need wiring diagrams for the ECU first. Hey buster, who do you know that can do it locally? let me know with a pm or something.
hey you have to do some rewiring cause the factory alarm wont set while the car is running. I bought a new greddy ooen but am going to wait for the harness.
Speaking of Turbo timers, do you guys plan on running the timer on after every drive? Whether, if it's a short 10 km drive to the locate store or 100km on the highway?
How long should one set the timer for ?
Depending on which turbo timer you bought, there may be a feature where it automatically knows how long the timer should go one for. I know my Apexi TT has this feature which is why i have to tap into the O/2 sensor of the ECU to wire it.
I have an aftermarket Alpine which will allow my car to run and still let me arm the car as soon as I get out.
Hey..so do u know where is the ECU and how to access to it?
newbee
Hi, does anyone know how to fix the wiring cause the factory alarm wont set while the car is running. I have greddy turbo timer.
I just looked at that TT post again and it wasn't very clear on the ECU pinout. I used pink/blue wire at pin 60 for the o2 sensor and the black wire at pin 103 for ground. It works!
