Turbo Timer Help!
ElSpeedDiablo
Mazdaspeed3
Hey I'm a fairfax county local and I'm looking into buying a turbo timer. I was thinking of buying this one http://cgi.ebay.com/ebaymotors/HKS-...ryZ33742QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I was asking the guy some questions and he said I would need to purchase a harness from him, is this true? I was under the impression that all I needed was the timer. Can anyone with some knowledge please let me know so I place the right order! Also the reason I posted on VA was because I'm scared of messing with wiring and was wondering if there was anyone local that would help me install this thing and I'd be willing to throw a little dough down your way for your time. I did the intake myself, but that was somewhat easy, but when it comes to wiring I don't have the slightest clue what to do so if someone out there could lend me a hand it would be great! Thanks to anyone who helps!
You don't need a harness, lawl. Just the unit and the wiring. Once you know which wires to tap into, it's a simple solder job.
There are writeups for install in other forums out there. There is no harness for our car and probably never will be. Just be a man and solder that s***.
None around here willing to help out, I already ordered it so too late to be changing my mind, but I drive that car hard and I sometimes forget to sit in the car for an extra 45 secs?
three wires in the steering column, and then the one on the ebrake, i just used those nifty blue clips at autozone that self tap into the host wire, no cutting or soldering involved. and then i use the female quik connect ends to connect to the turbo timer, I had the same one as you.
