perfworks said:
good idea, ill do that once i have posted the prices![]()
you're picking one up for me two?paulmp3 said:i have off work tomorow, ill give you a call in the morning.
ill talk to paul in the morning and we will make arrangements.jaje said:you're picking one up for me two?
perfworks said:our software comes out on the 12 th of july paul. We will make arrangements for you and jaje
srd555 said:
Well, did you get the software? is it up and running?
I have a question about the piggybacks operation that I cannot seem to get clear on.
Lets say I have a presetable boost controller, like the Greddy Profect B, and I have 6 psi (stock) and 10 psi set as the presets. Will your system be able to compensate for that much change in boost whenever I hit the button?
Also will the piggyback need to be reprogramed later when I go FMIC and 2.5" turbo back but still using the same 6 and 10 psi?
