A
AGR
turboge said:At 5000+ miles now, and I notice the stumble every time. It occurs between 3000-4500rpm. This turbo is very hesitant below 3000rpm, and doesn't completely spool tilll approximately 5000.
From my mazda turbo engine tuning experience I believe that it is all related to the ECU. Either the car is poorly programmed to handle boost in those RPM ranges, or the knock sensor (if even equipped) is wigging out. Other things lead me to believe that the boost solenoid may be incorrectly programmed as well, and that it may be "cycling" its signal and creating some kind of boost spike. A boost gauge is not on the car yet so I can't tell on that one.
Either way, this is not normal of a "stock" turbo'd car. Also, this is a rather small ball bearing turbo, I would expect full boost to be delivered by 3000rpm and held smoothly from then on. I've tuned on larger ball bearing turbo's and have had no problems with lag like this.
Also, there is a way to cure some lag. Free up the intake, and the exhaust. The free'r the turbo can flow the quicker it will spin for you. I've seen drops of nearly 1000rpm for complete spoolup on GT-R turbo's with intake and exhaust mods. We'll be modding soon to find out.
Good info! Thanks Braden. It isn't really consistent on mine, but happens once in awhile. I will be interested to see your later posts regarding this. And; I do want a boost gauge. Are they a pain to install? And; which do you recommend? Thanks!
Cheers!
(drinks)
