turbo inlet?????????
i haven't floored it yet on the freeway to check my psi boosting yet. As far as who i got it from the username is craighjr he built it custom and sent it to me for $75 shipped. He may only have 1 but if he has more he probably would sell it to someone. The turbo is much much louder with this.
quick question if i ever replace my turbo with a bigger one... wont i need to replace the inlet pipe to fit? i have the stock turbo now obviously but i was just wondering down the road. and i want the cp-e
the turbo inlet i have it 2.5 and the silocone coupler elbox tapers down to 2.0 to mate with the turbo, so if you got a larger turbo that had a larger opening, you could just get an elbow with the same diameter on the end to match up right. You wouldnt have to go so far as a cp-e, Plus if you are going 3-inch cpe you would have to buy a 3-inch intake as well to match up.
well i have their intake so would it match up?
cp-e's is a 3in camber. ends will fit like it should so any intake will be fine on it. it will be dumb finanical/development move for it to not fit like stock to accept other intakes.
sounds like a bottle neck? 2.5 size intake to 3 inch chamber back down to 2 inch turbo side? ah well.
I am satisfied with the custom one i got which worked out pretty good when driving today :)
they've taken this concept
the ends will fit any application while the camber smooth the increase air flow.
It's the ubiquitous whale penis intake!
hey just curious on what tools you need to install this? im guessing sockets to get the battery box and s*** out right but what else
there hasn't been updates on neither silicone inlets. patience will come out in the end with all the parts coming out for the MS3. waiting just means it goes through better design changes.
