gboromsp said:
So you are saying that Mobil 1 is not a true synthentic but has a dino oil base?? I may be wrong but I thought Mobil 1 was a true synthentic, just like royal purple, amsoil, or redline. Someone please clear this up.
<table border="0" cellspacing="0" cellpadding="2"> <tbody><tr><td valign="top">
What is Mobil 1 and why is it now called Mobil 1 with SuperSyn? </td> </tr> <tr> <td valign="top">
</td> <td valign="top">
Mobil 1 is a fully synthetic motor oil for automotive engines. It is made from a unique combination of high-performance fluids, including polyalphaolefin (PAO), plus the SuperSyn anti-wear system for protection under the most extreme use. Mobil 1 with SuperSyn is available in five viscosity grades:
- Mobil 1 with SuperSyn 10W-30
Higher-Mileage Vehicle Formula
- Mobil 1 with SuperSyn 5W-30
Newer Vehicle Formula
- Mobil 1 with SuperSyn 15W-50
Performance Driving Formula
- Mobil 1 with SuperSyn 0W-30
Enhanced Fuel Economy Formula
- Mobil 1 with SuperSyn 0W-40
European Car Formula
Mobil 1 with SuperSyn is truly a global formulation, exceeding the latest standards from the government, the oil industry and vehicle manufacturers. For instance, the appropriate grades of Mobil 1 with SuperSyn exceed ILSAC GF-3, API Service SL/CF, European ACEA standards and Japanese valvetrain requirements. In addition, some viscosity grades exceed specific OEM standards. One example is Mobil 1 with SuperSyn 0W-40, which exceeds Mercedes Benz's 229.3 specification. As a CF rated oil, Mobil 1 with SuperSyn can also be used in diesel engines calling for a CD oil.
</td> </tr> <tr> <td colspan="2" align="right">
back to top</td> </tr> <tr> <td valign="top">
What's the difference between a fully synthetic and a semi-synthetic motor oil? </td> </tr> <tr> <td valign="top">
</td> <td valign="top"> All motor oils are made up of base oils and additives. In general, fully synthetic motor oils contain non-conventional, high-performance fluids. Semi-synthetic oils (also called "blends") usually use a small percentage of non-conventional, high-performance fluids in combination with conventional oil.
What's the overall benefit of Mobil 1 with SuperSyn? </td> </tr> <tr> <td valign="top">
</td> <td valign="top"> The overall goal for Mobil 1 has always been to protect your engine, even under the most severe conditions, such as very cold starting temperatures, extreme high-temperature operations and high-load conditions. With several car manufacturers now extending or varying oil change intervals, Mobil 1 with SuperSyn has been formulated to provide more performance reserve. But Mobil 1 with SuperSyn is not just for extreme service. You can also realize Mobil 1's benefits of improved engine cleanliness and long engine life under "normal" service.
Is Mobil 1 with SuperSyn a fully synthetic motor oil? </td> </tr> <tr> <td valign="top">
</td> <td valign="top"> Yes, it is. To meet the demanding requirements of today's specifications (and our customers' expectations), Mobil 1 with SuperSyn uses high-performance fluids, including polyalphaolefins (PAOs), along with a proprietary system of additives. Each Mobil 1 with SuperSyn viscosity grade uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application.
</td></tr></tbody> </table>
