tt still messed up
wfmrules3
I am just trying to see if anyone has ever had this problem. I have the blitz dual tt and used the tt directions on this site to set it up. Everytime I have to take the key out really fast and the rpms will drop to zero and then go back up to idle. If i dont take the key out it will just turn off but the radio and stuff will still be on for a minute. I have tried everything to fix it. Anyone else ever heard of this or had this problem. Thanks a lot.
When I installed my blitz tt I had the same problem with the engine turning off but the radio staying on.
There are three wires under the steering wheel that you spliced into. The red goes to red. Try switching the other two. I can't remember how it's supposed to go. But I switched those two wires and it worked like it was supposed to.
used the wrong accessory wire.....did the same thing....took me 3 hours to figure it out with the help from another board member here.
i belive it's a blue wire....check in a how to section for hks install....it should be the same wires.
