Man another two tsb's just came out for the 3...i think you guys actually have as many tsb's for the 3 right now, as the 6 had in the past 2 years!
Here's the new ones...
01-028/04 MAZDA SPECIAL PROGRAM (MSP05) - 2004 MAZDA3 - O2 SENSOR DTC ERROR, P2195 / P2196
APPLICABLE MODEL(S)/VINS
2004 MAZDA3, 2.0L Engine, PZEV (Partial Zero Emission Vehicle), built from September 29, 2003 through July 2, 2004 (California Emission Regulation Applicable Model only)
- VIN Range: JM1 BK**F* 41 100220 - 206392
DESCRIPTION
It is possible that the DTC for O2 sensor failure may not be displayed appropriately. The DTC P2195 (Front HO2S Signal Stuck Lean) and DTC P2196 (Front HO2S Signal Stuck Rich) may be displayed in reverse. The DTC P2195 may be displayed in case of "stuck rich" and the DTC P2196 may be displayed in case of "stuck lean".
01-029/04 2004 MAZDA3 - FUEL DELIVERY MODULE (FDM) INSTALLATION
2004 Mazda3
-) Federal specification 2.0 / 2.3L, California specification 2.3L
DESCRIPTION
When replacing the fuel delivery module (FDM) for service related concerns, care must be taken during installation to maintain proper sealing. Use the following repair procedure whenever removal or replacement of the fuel pump is necessary. It will be made available in the Workshop Manual in future revisions.
09-030/04 2004 MAZDA3 - FRONT WIPERS DO NOT WIPE WELL
2004 MAZDA3 with VINs lower than JM1 BK**** 41 207550
DESCRIPTION
Some vehicles may exhibit front wipers that do not wipe well in cold weather. In cold weather, the wiper rubber hardens and its shape changes. As a result, the wipers do not fit properly on the windshield.
The pressure has been increased on the new wiper arm to correct this concern. Customers having this concern should have their vehicle repaired using the following repair procedure.
09-031/04 2004 MAZDA3 - LOOSE DOOR TRIM SCREW CAP
2004 Mazda3
DESCRIPTION
Some vehicles may have a door trim screw cap that is loose and stays open. During production, the cap may deform and will not stay closed.
To prevent tab from deforming, the shape has been changed. The screw cap is now modified and also available separately as a service part Customers having this concern should have their vehicle repaired using the following procedure.
