trunk leak
Pull all the carpet up and silicone all the seams including where it goes up to the tail light. If that doesn't work replace the trunk seal. And if that doesn't work then your car is like mine it just wants to leak. Spray it done real good with the rust proof stuff and pull the drain plug
Mine leaks all the time. My car starts to smell when I dont drain it after a while... speaking of, I should go do that right now
Just leave the drain plugs out. If you let water sit there it will rust through
+1 i pulled m drain plugs on both sides once i found out my scissor jack was completely rusted and non functional anymore.. but i still need to rust proof my car
did mazda also have rust issues with th rear quarter panels? my driver side wheel well is rusted
