well... if you want them i'll sell them to you...
but they don't work perfect
yup it changes color when you turn your signal on
they are very nice and bright... especially the white
but it turns your signals into high speed flashers...
imma see if i can return them... guinea pig tested and not approved
or i might try this
Load Resistor Kits:
6 Ohm, 50 Watt resistors can be connected across the turn signal wire to simulate the load of a regular filament bulb (2 Amp load). This will solve LED related turn signal problems such as hyper flashing, no flashing or burnt out bulb indications. One resistor is required for each turn signal bulb. Kit includes two resistors and 4 gel filled moisture resistant splice taps.
Connection Instructions:
Using the included splice taps, connect one wire to ground and the other wire to the turn signal wire. You do not have to cut your car's wires. Squeeze splice taps with pliers. One Load Resistor required for each turn signal bulb. No instructions are include with these kits.
