MazdaVirgin
- Mazda 3 SP25
Hi everyone,
I have successfully replaced all the interiors light bulbs with LEDs as well as the exterior number plate lights.
The trunk/boot light - I have tried several LEDs from various manufacturers including the '5k white 3 LED WEDGE base 37 74' from VLEDS and I have found them all to be too dim.
Does anyone have any suggestions on alternative LED bulbs that is really really bright?
As a last resort I do have a fairly bright battery operated LED light that has movement sensor so that if you put it in the trunk/boot and then open the trunk/boot, the light will come on but the time on it is too short (only about 10 seconds) and there is no timer override.
All constructive suggestions is appreciated.
