Keith@FM said:Just remember - anything that can be adjusted, can be adjusted wrong
We had a Civic Si on our dyno here with adjustable cam gears. We strapped it to the dyno and started tweaking. He gained 25 hp and had a much smoother curve when we were done. It wasn't that he GAINED 25 hp from the gears, he'd actually lost at least 15 when he installed them...
Keith
APEXistud said:
I knew something was up with that dyno. A member on here a while back posted that dyno and he was trying to tell everyone that he gained all that power from just installing the cam gears only. I was like yeah right. But he swore up and down that he gained all that from tuning the stock cam gears.
20ESGUY said:Regarding the install, if you did the j-spec cams at the same time wouldn't you have to get a whole new shim kit to adjust the valve lash with the new cams??
