Tripoint cam gears and JDM cams install
ogsp5 said:
There is nothing wrong with your sensor. Just install a washer between sensor and housing. This will pull the sensor out and not hit the the cam gear. I have mine installed for over 2 years with no problem. Both gears are set at -3 and the car pulls great at around 5k. You can also check with our Aussie Mod. He had the same problem till we had a little chat on this same problem.
ahemmm. . . 3 y/o thread.
