kulkarnipb
- 2012, CX-9 Touring
I have 2012 CX-9 Touring AWD. So far ran 50k.
While going through the forums , I realized that CX-9 has significant issues with the transfer case and I really need to take care of it. However, I came across some doubts -
1. Transfer case has only one plug. I have to pump out fluid from it and then fill new through the same. Correct ?
2. Owner manual says - I have to use SAE 74W-140 fluid. Can I use a 'synthetic' SAE 74W-140 ? ( like - https://www.amazon.com (commissions earned) )
3. Normally , what should be the frequency to change the transfer case oil ?
Thanks in advance.
Thanks in advance.
