While I was checking the "play" of my gearshift the other day (the car was turned off), I noticed that I could almost shift my car out of 3rd gear without stepping on the clutch. While driving, I noticed that I could get the gears to "grind" when the car is in 3rd and the clutch is not pressed. I could not duplicate this with any other gear. I am usually good with my tranny and have only mis-shifted a few times (failing to remove myself completely from the gas pedal when shifting).
Is this normal or do I have a problem?
