supersuckers
I own a 09 MS3 Sport. A month or two after purchasing the vehicle, the TPMS warning light came on. I immediately checked the pressure and found all of the wheels to be w/in spec (34F & 32R).
After ignoring the light for several months I had my dealer investigate. Their solution was to inflate all four tires to 35psi. They told me that the sensors are set to 35psi and will send an alert at when the tires are +/- 2psi. This basically means that my rear tires will generate an error any time they are set to Mazda's advertised spec. Unfortunately, there's no mention of the expected behavior of the TPMS sensors in the owners or workshop maunuals.
1. Has anyone had a similar experience? How did you resolve?
2. Is my dealer correct? Seems way too sensitive.
3. Is there a way to cripple the TPMS such that the idiot light remains off?
4. Does Mazda have less sensitive sensors that will work with the Speed3?
5. Are the sensors temperature aware? Do they account for pressure changes while driving?
Thanks!
Thanks!
