Tow Hook License Plate Adaptor for a 2020 CX-5 Reserve
ddingle
2020 CX5 GTR
I just got a slightly used 2020 CX-5 Reserve and I need to mount a front license plate. I am thinking about a Tow Hook mount, but wondering if it will block any of the lasers in the front? Anyone know if the Tow hook mount will interfere with any of the sensors? Thanks
HardRightEdg
US 2020 CX-5 Touring AWD Soul Red
I don't why you would do this or how far it would stick out, but consider the following:
The front facing radar is behind the Mazda logo. Knowing what it used for, it shoots down the road more or less parallel to the ground. So that should not be an issue. But if you want to test for obstruction you can. Per the manual, "The Mazda Radar Cruise Control with Stop & Go function (MRCC with Stop & Go function) system is operating, a single beep sound is heard when “Front Radar Sensor Blocked” is displayed in the multi-information display." If you already have the hardware you could put it on and try it. If not, I suppose you could could do something like putting a box or other object on the ground taking up the area where the hitch would be, then engage MRCC with Stop & Go and see if you get the warning. You could go crazy with it by covering the radar first just to be sure the warning function is working in the first place.
The front facing camera at the top of the windshield is also not a problem. It shoots down the road and even if it didn't it's pretty clear it's line of sight is obstructed by the hood until several feet in front of the bumper.
That leaves the other front camera. In one place in the manual it says it is in the bumper; a diagram shows it next to the logo, which does beg a question as to where it is exactly. In any case, the only thing the manual says it is used for is the 360 View Monitor which agrees with a diagram showing it pointing down directly in front of the vehicle. I don't have the 360 view; somebody who does might see evidence of where the camera happens to be. I don't know without looking it up if your 2020 GTR might have this feature. If not, no issue. If so, the installation of the hardware or the box test is easy enough to do by just looking at the 360 display.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
I have a tow hook plate mount on my CX-9, and the only thing it interferes with are the front parking sensors. I don't think the CX-5 GT Reserve has front parking sensors, so you should be fine.
ddingle
2020 CX5 GTR
Thanks for the help on this! No the reserve doesn't have parking sensors. I will post a picture when I get things mounted.
Virginia
2021 CX-5 White
So what happens, can you still use the front parking sensors, or do you have disable them?
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
I have them disabled, and turn them on when I want to use them (not often). Its just annoying when I use them because they constantly beep due to the plate. That said, if I'm pulling up to a bumper, its like the signal "jumps" between the plate and the objects ahead, so I can see flashes of the sensors registering the bumper in front of me. Again, I rarely ever have to use the parking sensors, so its not a big deal to me. I've considered enlarging the holes on my license plate and grinding down one side of the bracket that the license plate mounts to, but it's a low priority for me at this time.
