Hazardous PR5
My '03 2.0 5spd Pr5 was coming up on 100K miles when the check engine light first came on. I'm meticulous about maintaining it and do it myself (oil changes at 3000mi, plugs gaped at 0.7, correct fluids, alignments, and octane boost/injector cleaner once a month). And she has always ran perfectly, however since the CEL came on I have thrown at least 7 codes and no one can tell me any definite way to fix the codes or the CEL. Off the top of my head, some of the codes were: random multiple misfire, valves stuck open, O2 sensor problems, catalytic codes, and those are just the ones I remember. While trying to narrow down problems and solution (mean while still driving it) I had my first real problem: While driving and cruising at a consistent speed, I lost power. Not total power loss, but it felt like a was down a cylinder... or 3. It wasn't misfiring or spitting but there was a huge power loss. I pushed in the clutch and the the RPMs fell to the bottom of the tac (200-50 RPMs or so) but the car didn't stall. The engine never shuddered or made any odd noises but after about 5-10 seconds of being in neutral the RPMs returned to a normal idle (about 1700 RPMs) and I put it back in gear and continued down the freeway, never having even stopped. This happened several more times seaming to occur about every 50 miles and only when I was at a low RPM cruise. I checked the O2 sensor, clean as a whistle, then cleaned the ERG valve which I found to be a bit sticky (at least I think it was the ERG valve. It is on top center of the valve cover, a black elbow, looks like PVC?). After that, the power losses seamed to stop or grow less frequent. However my CEL was still on. I was told to disconnect my battery and pull the fuse for the ECU for 5 mins to reset the computer and that if the CEL came back on, the first code it threw would be my problem. So i reset the ECU as I was told and after 97 mi it threw a cat code. My mechanic said the cat probably wasn't heating up fast enough and probably needed to be replaced.
Any one have any insight into my problem?
