Very simple, pull the shroud(2 10mm bolts), unscrew the worm clamps on both sides of the IC, and I believe your free. There might be 3 mounting bolts on the IC as well. Takes 15 min or less.
I am assuming you have done this yourself already? No vacuum hoses or anything of that sort is there?
Yes, I've done it myself without a how-to. Everything is straight forward and you should have easy access to all screws/bolts. Go pop your hood and see how far you can get, you should have no trouble at all.
