tire size
235/45-20 is quite a bit shorter than OEM size (28.3 in. vs 29.6 in.)......rotates 4.6% faster. You generally want to keep the diameter within +/- 3% or so of the OEM size. The smaller tire would also have a lower load carrying capacity....not good.
but there are tires on that size that have the same load rating though.
rotating 4.6% faster; does that mean its good?
