whiteproto02
- Protege5
I'm having problems with getting the right information on how to set up the cams once the cam pulleys have been removed. I recently took the head into a shop that replaced all of the seals and machined the head. They also cleaned to camshafts but had to have the pullys removed. I cannot find propper information on the possotion of the camshafts before installing the pulleys. It looks like the nods on the cams for the pulleys should be pointing straight up because this allows the notches on the pullyes to be alligned with the top of the head and pointing at each other. I know the crank should be pointing staight up at TDC. So far I have the the engine set up this way and fired it up tonight but it will not idle and it sounds like it is missing. Is this the right way of setting up the cams and pullys? I'm not sure what is going on. Any help would be great.
