Timing Belt
Lithius
Mazdaspeed Protege
Hi Guys, I searched everywhere for the timing belt installation + waterpump install in the How to section can someone help me.
And just to add another FYI, if you want OEM parts here are the numbers listed for everything that should be replaced during a timing belt installation.
BELT,TIMING Part No : FS01-12-205A
TENSIONER,TIMING BELT Part No : FS01-12-700B
SPRING,TENSIONER Part No : FS01-12-711
IDLER Part No : FS01-12-730A
PUMP,WATER Part No : 8AG9-15-010
V-BELT Part No : FS12-18-381A
V-BELT Part No : FS12-15-909A
does the tensioner and idler need to be purchased if the ones on right now are fine? i'll be doing this in a couple weeks. i'm contemplating whether i should get a aftermarket udp or not while i have it apart and have to buy different size belts for the udp
No it doesn't. I am going to replace mine when the time comes, because I'd rather not risk tensioner failure. I got lucky with my wife's car because it doesn't have an interference engine. Having the valves crash into my pistons isn't something I would even remotely take a risk on.
our engines are non-interference correct? i didn't think we had to worry about pistons and valves slapping...
well that's not cool. for some reason this whole time i could have swarned someone said they were non interferance engines. suck...ha. thanks for re-informing me!
