HombreDeFamilia
- '03 proteg LX
Primo walkthrough. And for all the guys out there having trouble with that crank pulley bolt, an impact wrench (even an electric like the one i just bought (DeWalt, 345 ft.-lb.) with 300+ ft.-lb. will zip that thing off in literally two seconds, found that out yesterday
. Make sure you apply a good high-temp silicone sealant (I like the red Permatex) right next to the cams where the gasket on the cyl. head cover stops (technically, you should replace aforementioned gasket as well), very important, seems to be the only thing missing out of this write-up. Cheers indeed!
