Time to forge
Both came from Protege5s, split the cases open and swapped the LSD's in. They are basically the same transmissions, the 03.5's (all proteges and MSPs) had an updated 3-4 shift fork but that's the only difference.
Awesome thanks a ton! I enjoyed the talks for sure. I looked up unichip and you can by their cable and software that will allow you to edit basemaps, they have a whole FAQ on it. I will be going to yard tomorrow to see if there are any protege 5s that call my name!
You can use the 93-97 2.0 FSDE Probe Manual transmission also, probably the 626 2.0 FSDE Manual Transmission also. I have a 96 probe tranny in my brothers car right now.
They will fit, but the transmissions were upgraded over the years so the newer the trans the better. Not to mention the newer transmissions will likely have fewer miles.
