Throttle System/Brake System
Speed03.5
2003.5 Mazdaspeed Protege
Another problem with the MSP (silverpro. May someone please send a pic of there engine bay of the throttle system?
Is there a hose that is connected or a plug or something. I have a cheap 6 dollar fix in the throttle right now to stop the loud whistling.
Also brake light is on, but no brakes are on possible solutions.
Thanks for the help
Thanks for the help
I'll gladly help you, but I don't understand what you're asking or what the problem is...
The throttle body has something missing from it. I don't know if it's a hose or a plug of some sort. I'm sure whatever is missing is throwing the code for manifold. Considering it's the only air leak I have in whole car. I have the throttle plugged up right now with a panel screw and capped off.
For the brake system I'm sure it's just a re-alignment of the sensor considering I haven't seen any difference in performance with my brakes or e-brake.
It sounds like a massive air leak that is coming from the throttle. My engine is putting in double time comensating for the missing hose or plug for the throttle. It's very loud and very obnoxious haha
You take a picture of it...
there is only two hoses that go to our throttle body and they are both coolant lines. If you have a vacuum leak coming from the throttle body, it is going to be from the gasket between the throttle body and the manifold. Let the car idle and spray some carb cleaner around the gasket area and see if the idle changes. Does the car idle roughly? Have a boost gauge, if so, what is your vac like? Here are some pics of the throttle body:
Throttle position sensor side, notice the two fittings where the coolant lines would go
throttle cable side
direct front shot
HTML fail... Try again. You're going to have to use a host like Photobucket or Imageshack...
That picture sucks... It gave me a headache looking at it... It looks like that's the throttle cable cam, though... But, like it was stated before there is not vacuum port on the throttle body...
Lol you thank verizon and the bad phone I have.
I have to wait till I get in the garage and whip out the NIKON that is the best I could do for right now. I bet that's 100% it. Let me try and get a better pic. Be right back
na, it's not that. What you are talking about is on the bottom right side of the throttle body, like in the last pic I posted. This is on the top of the facing up. I can see how it looks like it though because of the angle of the pic
if you look at my second pic I posted, you will see that is supposed to be a screw in that spot
Yeah, now I can tell what his pic is...
With that being said... You have two different problems... The brake concern will be unrelated to this.
And OP, if worse comes to worst, I have like 5 throttle bodies if you need to buy one.
