oldenglish82
- 2012 Mazda 5
We just purchased one thrusday and only have 120 miles. My questionis warranty. Will this affect my warranty at all?
I may give this a try, how long is the cable and do you have a photo that shows the entire 'run'? I'm a mechanically challenged.
Update sought: any thoughts on MPG effect, MarkVII88, in the intervening months? Merely curious, likely gonna try this mod in any case. Thanks.
...most modern EMS programming was established to lessen the emissions output of the motors, so
throttle opening and closing delays have been implemented to lessen the emission output of the
motors...not to piss you off.
This is one of the key points COBB pointed out. Below is a summary from their research (full link is dead). I do agree DBW is good for the common consumer. Its all about making the car easier/efficient/safe for the lowest common denominator (smarter than you). It also allows integrated systems to work together but like everything else in life, there are tradeoffs.My problem with DBW systems is the "i'm smarter than you and I say you don't need 100% throttle when you floor it" syndrome. I noticed this much more on my 08 Honda Fit than with my 06 Mazda. My Fit would simply refuse to give me more than 3/4 throttle, period, end of argument. So I got a Three Drive throttle signal modifier. I basically boosts the amperage of the signal coming from the pedal going to the throttle plate. The difference in that car was absolutely night and day, it drove like a cable throttle car from that day forward. My mazda doesn't seem to have that problem (so far)
What this means to you:
...most modern engines will never show a 0% TPS since the throttle blade is always kept open (by 2-7%) to start the engine and to maintain idle.
...some modern engines will never report a 100% TPS while at WOT since their TBW system may have been programmed to only open up to a predetermined point.
...you can change the Rev Limits on an engine by tricking the ECU about the reported RPM but you may not be able to get the motor to accelerate past a certain RPM since the throttle body has been programmed to close by a predetermined RPM.
...porting of most modern throttle bodies is not a good idea unless you have the ability to fully recalibrate that system.
...most modern engines will not allow the motor to start immediately after the battery has been
disconnected then re-connected or if the ECU has been re-set because the systems needs approximately 5 seconds to fully calibrate the TBW system. If the battery has been disconnected then re-connected or if the ECU has been re-set, please allow the key to stay in the ON position for a minimum of 10 seconds to allow the TBW system to calibrate before you try to start the engine.
...providing a constant +12V to the throttle actuator motor will fully open the throttle blade, providing a constant -12V (reversing the polarity) to the throttle actuator motor will fully close the throttle blade.
...most modern EMS logic has been calibrated to control the throttle blade opening and closing speed. We have seen where the throttle blade actually opens slower if you slap down the gas pedal versus gradually depressing the gas pedal.
...most modern EMS programming was established to lessen the emissions output of the motors, so throttle opening and closing delays have been implemented to lessen the emission output of the motors...not to piss you off.
...most modern vehicles have some sort of Traction Control System which use the Electric Throttle Bodies to control engine torque output.
...most modern vehicles have some artificial throttle response programmed into their control. For instance, if the driver is pushing down on the APP 20% the TPS sensor may report a 50% reading. The ECU is creating artificial throttle response by opening the throttle valve much more that the driver is requesting.
