As stated before by others that this ECU fix works, it DOES NOT. :mad:
http://www.zzperformance.com/zzp/products/prod_o2_simulator.htm
I got it today, and it simply does not fit. No, im not an idiot. Its for a Grand Prix and WILL NOT fit. I have to send it back and order the ECU fix from Apex motorsports, as they are the only people to make the fix for our car.
Their fix is a resistor based fix, and quoted from Ben this is how it works:
When your CEL comes on your car reverts to stock fuel mapping, no matter what you have installed, so you are not getting the full potential from your mods (like when you reset your ECU to get it to "learn" the new mods). This fix will turn off the CEL, allowing you to reset the ECU and re-learn with the mods you have installed, allowing you to get your full potential. This is especially true when your mods are completely to do with air/fuel, like intake, header, exhaust, no cats, like mine.
If you have ordered this product based on that other thread, i suggest you attempt to cancel the order before you get the product, or wait and send it back with a note saying that it will not fit to the same address with the top line reading: ATTN: Returns.
Here is Apex Motorsports in Tempe, AZ. Their fix is meant for the protege, and requires some wire splicing, which im sure is not hard. We'll see how this works, and ill add to this thread when i get it.
Apex - 480.967.6515
Apex - 480.967.6515
