Hello! I am looking at a 2014 Mazda 3i Touring. Here is what I know are known 'issues' from the seller.
72k, clean title automatic,
Minor washer fluid line leak.
Air fuel ratio sensor wiring harness sheathing damaged. We repaired/replaced the sheathing. Why would this even be damaged in the first place?
Timing cover gasket should be replaced
Drive Belt Tensioner Seeping
Drive Belt has wear
Vehicle slightly pulls to the left. seller rotated the tires and this seems to fixed the problem.
Seller is asking for $9,500
Thank you so much!
Listing info...
72000 Miles, clean title, automatic. asking $9,500
- In late 2014/ early 2015 the front passenger quarter panel was injured in a fender bender and was all professionally fixed by insurance. It was put back to new and you couldn’t even tell there had been an issue.
- We have had regular oil changes through its life, brakes redone a couple of years ago, all the air filters/etc. changed, changed the tires a couple of years back and the tires are all in good shape. It has relatively low milage, so hasn’t needed much else done.
- One of the ABS sensors to a wheel needed to be changed about 2 years ago, it caused a light to come on on the dashboard, but was a pretty easy fix with my mechanic.
- There is a chip in the windshield, some scuffs and dings around the car, so the paint is definitely not perfect but still overall good.
- I had the dealership add Apple CarPlay and upgrade the USB chargers about 1 year ago for better synching and charging of my phone.
- It has always passed smog checks, we just got an updated one and can give the buyer the certificate
- We had an inspection done with a Mazda dealership recently and overall it is in good mechanical shape. Here are a few things they noticed-
-Cabin air filter dirty. We replaced it.
-Engine air filter dirty. We replaced.
-Minor washer fluid line leak. This is in the tube that goes from the tank to the window, we have never noticed it losing fluid and still works perfectly.
- Air fuel ratio sensor wiring harness sheathing damaged. We repaired/replaced the sheathing.
- Timing cover gasket should be replaced. I have never seen any leaking.
- Drive belt tensioner seeping.
- Drive belt has wear.
- Vehicle slightly pulls to the left. We rotated the tires and this seems to have fixed this.
- Small chip in windshield.
- No DTCs. (No error codes).
Drive Belt has wear
Thank you so much!
Listing info...
