Theft deterrent reset
When investigating an ABS light issue I disconnected the wiring harness in the fuse box. After reconnecting the harness the car now won't start. Security light is flashing when key is turned.
Maybe it will help if we know what year car at least?
In these cases, where the programming may have been lost, you may need to call a mobile locksmith.
I had a similar issue, and I just removed the entire security immobilizer system on a 2008 Mazda 3 following the manual backwards. I could then start it with the key and had to go to a locksmith to get the key fobs reprogrammed.
Update: I contacted a very friendly local garage. He suggested I disconnect both battery terminals and hold the wires together for half an hour. Guess what? It worked! Make sure the wires are nowhere near the battery if you try this.
