the will it fit game
GLA45
i have leftover wheels/tires from my last car. the wheel specs are:
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - 8"
PCD Bolt Pattern - 5x114.3
Offset - 35mm
Hub Bore - 73mm
the tires are 245/40
so what happens if i put them on? tire rubs fender? tire sticks out beyond edge of fender? black hole opens up and swallows car?
The offset is too low. You want at least a +40mm. You will be well past the fender... if you don't have camber... they will shatter your fenders.
