this below.....
but it is far from plug and play, see Mazda3 link below, I got them cheap during their sale and it will fit the OEM brackets at the required 3 mounting points but need to shave a lot of plastic off in the bracket rear to make it fit, I haven't gotten a chance to install them yet, looks like a universal HID projector housing and they provide a molded bracket to fit into existing OEM bracket but the OEM bracket opening in the back needs to be Dremel'd out, I got two spare OEM fog brackets from RockAuto about $6 each so I can mount them, I'll post pictures and video after I get them installed.
HID projectors ?
http://mazda3revolution.com/forums/2014-2016-mazda-3-skyactiv-appearance-interior/174426-hid-projector-fog-lights.html
http://store.ijdmtoy.com/Mini-HID-Bi-Xenon-Retrofit-Projector-Fog-Lamps-p/70-126.htm
AGREE for you blackcx5, I got the projector fogs from iJDMToy.com and they are indeed FAR from plug and play,
but thanks to your heads up at least I knew what I was in for...
they're on sale now for about $100 use code : EGG15
I left my OEM fogs alone until I knew for sure I was able to mount the projector foglights, so I got duplicate fog brackets from eBay
http://www.ebay.com/itm/MAZDA-OEM-CX-5-Foglight-Fog-Driving-Light-Lamp-Lamp-Bracket-Left-KD5351694A-/272441564185?rmvSB=true
http://www.ebay.com/itm/MAZDA-OEM-CX-5-Foglight-Fog-Driving-Light-Lamp-Lamp-Bracket-Right-KD5351684A-/282249262848?rmvSB=true
these are the aftermarket HID projector fogs from ijdmtoy, they only provide the plastic sleeve that mounts onto the OEM brackets, they don't privide the whole OEM brackets that need to mount to the car bumper.
problem is they don't fit the OEM brackets unless you remove a lot of the plastic from the brackets.....
you'll need a 90mm hole diamond drill for $6
http://www.ebay.com/itm/Diamond-Tipped-Hole-Saw-Drill-Diameter-90mm-Bits-For-Glass-Tile-Slate-Granite-/252288859324?hash=item3abd967cbc:g:OeYAAOSwYGFUzth~
just use the 90mm bit to get the general circle shape then you'll need to use a dremel to cut out the smaller pieces,
you'll have to constantly to a fit check with the aftermarket sleeve to determine which plastic area to remove....
once you have that done, the aftermarket sleeve should fit in nicely
it can swivel similar to the OEM fog housing........
then it's just a matter of mounting the projectors and then mounting the assembly to the car......
needed to get a right angle type HID bulb, the passenger side with the washer fluid tank is very close
I'll post video later this week so members can compare HID projector vs the Morimoto LED's and then decide which one suits their needs better.....
