Listen,
I am tired of everyone complaining about not having the superior z828 headunit. Here is your fix. Bite mazda in the ass.... Heres how, have someone who knows what thre are doing do one of two things
1. Blow the outputs on the head unit. Covered under warranty. Too bad 919 is not available, you get a 828
2. Blow the faceplate. Covered under warranty. Faceplate too expensive to fix, replace head unit. same as above.
Having said that, be careful as it cannot look as if the unit was tampered with. Consult a stereo shop if you know someone. The dealer will most likely replace it without sending it to kenwood first.
Also, to everyone who thinks this will not work, I have a Z828 in my dash that says otherwise.
Finally, this is not legal and the only reason it was done was to teach mazda a lesson. If this causes me trouble(from this board) I will deny everything.
Just trying to help all the z919 people
Later
Later
