I own a 2000 Mazda Protege LX 1.6L auto. Ok, recently I notice the temperature gage climb to 3/4 at really hot summer days. If I don't turn on the A/C, the temperature gage will stay slightly below 1/2, but once I turn on the A/C for 10-15 minutes, then the temperature gage will slowly rise to 3/4, and then couple minutes later slowly drop back down to slightly below 1/2. Yesterday it was close to 100C in my area and I notice the gage climb to 3/4, so I immediately turn off the A/C to let the engine cool down. But it will still climb higher than 1/2 like say to 3/5 but it drop down after 2-3 minutes and then raise back up to 3/5 2-3 minutes later. It raises and drops slowly and happens every 2-3 minutes cycle. So what's going on here?
This only happens when its really hot outside and doesn't happen when its colder weather like say less than 90F. I mostly do highway driving and maintain 60-65MPH.
1. When the engine is cold, I open the radiator cap and the coolant is green topped, so I can assume the radiator cap is good and coolant also good.
2. When I turn on the A/C, both fans are on. However, the fan close to the water pump blows really hot air and the other fan blows hot air, but not as hot as the one close to the water pump.
3. The drive belt has been changed 2 months ago and that includes the water pump ac and alternator belt from Meineke. I even had them check for my cooling system for any defects and they told me everything is fine. They plug a computer into the car and check for any problems. They told me your fans are working when A/C is on, your coolant is at full and looks good, and your thermostat is opening when its hot and there is good flow in the cooling system. Probably its just a really hot day and you experience that and your cooling system is fine.
4. It could be the coolant temperature sensor is faulty, but at colder days it stays below and goes to when its really hot outside and then drops down to after 2-3 minutes. That seems normal to me
Im out of ideas here (uhm)
