Tekkies emanage dyno
I am going to get the spokes powder coated gunmetal once I find somewhere to do it locally
18x7 KMC Wizdom rims, 42 offset :(, 215/35/18 Kumho 712 tires
I guess fendor rolling will be coming into play once I lower it for sure
it depends how low I go, I guess I will have to wait and see once I get coils on there, but I am pretty sure that they will rub the middle of the tire
Jamie, you will be fine with a 7" +42 offset wheel.
this is the comparison to my wheels (18 x 7.5" +45):
The clearance from stut housing to the inside of the wheel will be 9mm MORE
The outside edge of the wheel will RETRACT in towards the body by 3mm
furthermore I have never rubbed in the middle of the wheel, its always been at the 2 o'clock position on the right rear, and the 10 o'clock position on the left rear. not to mention all my rubbing stoped when I rolled this area.
as long as you dont try to pull off a 225 wide tire or a really tall sidewall then you should be fine.
lol I did not mean the middle of the wheel, I meant the middle of the threadwall :) right now it looks very very close, either way I am not worried, nothing that cant be fixed :)
hey tekkie,
with you e-manage how did you wire up the ignition harness? I have the wiring diagram for the injector harness but it doesn't look like it has anything for the ignition harness? I didn't know if you knew where i could get this?
Thanks
