kelvincheu
Has anyone tried this on CX-5? Does it make a difference?
With Direct injection the injector is inside the combustion chamber so you loose this benefit.
Very good point.
I guess the detergent can only clean the injector and combustion chamber, not the intake valve. Also, looking at the manual I did not find any recommendation for Top Tier Gas. As an owner, I would have expected a mention if this is what Mazda recommends.
For DI engines, I've heard of concerns about carbon build-up on valves and downstream systems but don't see how a detergent can clean any of this. It might be worth while to get a gasoline with detergent for the sake of the injector alone, but I am not sure.
Here in CA, different rules are imposed on refineries on how to produce gasoline and there are only a handful of refineries which do that. So, other than detergent and possibly stale gasoline I am skeptical that gas station A will have better gas than gas station B, especially if they get the same amount of business. Perhaps I don't understand enough what 'quality gasoline' means.
With our other cars (non of which are/were DI), I've always looked for a gas station which has high turnout and low prices. We never had problems related to the fuel system, but it is true that we also typically don't keep cars beyond 100K.
From Costco website:
Types of Fuel and Fuel QualityQ: Is Costco TOP TIER™ certified?A: Yes. Both grades of gasoline sold at Costco meet and exceed TOP TIER™ requirements. The owners' manuals provided by the following manufacturers recommend using TOP TIER™ gasoline to maintain optimal engine performance and efficiency.
•BMW, including Mini Cooper and Rolls-Royce
•General Motors, including Buick, Cadillac, Chevrolet, and GMC
•Honda, including Acura
•Toyota, including Lexus and Scion
•Volkswagen/Audi, including Porsche, Lamborghini, and Bentley
•Mercedes-Benz, including Smart
Q: How does Costco assure their gasoline is high quality?A: There are two aspects of fuel quality that depend on the gasoline brand and the individual retailer: deposit control additives and station maintenance.
Deposit control additives
Since 1995, Federal regulations mandate that all gasoline contain an EPA-approved deposit control additive. These additives are designed to minimize engine deposits that can affect vehicle performance and emissions. The various proprietary deposit control additive formulations are the main difference between brands of gasoline. All Costco gasoline, both regular and premium unleaded, contains deposit control additives. As of March 2014, all Costco gasoline meets and exceeds TOP TIER™ requirements (www.toptiergas.com/retailers.html). With five times the EPA required amount of additives in our gas, we are proud to call it Kirkland Signature™ Gasoline.
Station Maintenance
Good station operation and maintenance means the fuel is filtered and that contaminants, such as sediment and water, do not find their way into our members' vehicles. Costco gas stations are well-maintained by our capable attendants so you may be confident that the gasoline going into your car is clean.
•Costco uses fuel filters to catch particles or debris larger than 10 microns in diameter. For comparison, the average human hair is seventy microns thick.
•Our attendants check the nozzle flow rate frequently to assure that our filters are fresh. When the flow rate falls below 8 gallons per minute, we change the filter.
•Costco uses ethanol-compatible filters designed to catch sediment, water, or phase-separated ethanol and water mixtures.
•Costco's electronic sensors continuously monitor our underground storage tanks for water.
•We physically inspect and take chemical samples of our tanks at least weekly to confirm there is no contamination.
Q: What happened to "Clean Power"?A: Although we originally referred to our gasoline additives as Clean Power, we determined that Kirkland Signature™ best describes the high quality and great value of our gasoline. Kirkland Signature™ Gasoline: same quality product, much simpler name.
I'd say you are better off buying high octane gasoline giving the same end result.
Those cleaners you dump in the tank help out engines with multi-port fuel injection but do nothing for engines with direct fuel injection like the Skyactiv engines. The reason is with MPFI the injector is placed just before the intake valve and so when the fuel sprays it cleans the back of the valve. With Direct injection the injector is inside the combustion chamber so you loose this benefit. I suppose it might help clean the top of the piston but so do the detergents that are already in the fuel.
Don't do this...! High octane fuel is the same as low octane fuel except for MORE additives (wax) to slow it from combusting too quickly in a high-compression engine. Adding high octane fuel to the CX5 engine will, over time, create more problems. Use only the octane rating Mazda says to use.
Beefy, you can't possibly be serious...
