has anyone thought about a stand alone on the Protoge, with the new tec 3 out and a new haltech coming out, and the aem ecu, possibilites are endless. i don't know how much of you actually have stand alone experience, but it can be a pain, but the newer more advanced versions seem to be less of a PITA and more user friendly. since the mazda ecu will not be able to compensate for some of the power that some of you protoge owners are planning to make, it might be something to consider or look into. i personally am starting to take a liking the aem ecu
i have a couple of tec 2 questions for you (spoolin or whoever), since in the other thread you had said you had tuned your miata with the tec 2, you should be able to answer these for me, if not, i'll assume it was a typo and inquire to someone else that is familiar with the tec 2. if you aren't sure to the answer to one of the questions, just say so.
i'd appreciate it if you kept things civil, as it would be questionable if you weren't civil, just so that you could move this post.
i'll await your answer, if not, maybe someone else can respond to those.
1.) explain the specific method to upload a new file to the car (tec2) after changing parameters while driving around?
2.) explain the type of wire, and type of uplink used to go from the tec2 to the computer, as well as cable termination
3.) what is the maximum amout of fuel that you can remove for the coolant temp sensor correction factor? (for cold start parameters)
4.) how many turbo cars have you owned? my answer is 5
"Secondly I perhaps have owned more turbo and F/I cars then you have ever owned.
How does 320 rwhp sound out of a stock 1.6 liter motor sound to ya??
That was my previous car before I was t-boned and the car was destroyed. That was on pump gas with a tec 2 at only 14psi of boost on a stock miata block. If you think thats not impressive then your ignorant and that was good for 12.3 1/4 with soft launching cuzr I kept breaking rear ends. Do I ever brag about this? Most people dont even know I owned this car because its not applicable to the forum. "
