I am talking about highway cruising at 70-75 miles per hour......the only other thing i forgot is that the tranny has redline synthetic......it is so smooth even at 20 degrees.....I averaged 34.8 on the last trip....32 pounds air in the tiresadc0642 said:dammit that's hi mpg.
I've tried hi tire pressure, grounding the electronics, fancy spark plugs, moved to synth blend oil, remove roof rack, etc. etc.
car gets no more than 30mpg EVER.
well it might if i set the cruise at 55 but that's just silly.
doctormike said:I am talking about highway cruising at 70-75 miles per hour......the only other thing i forgot is that the tranny has redline synthetic......it is so smooth even at 20 degrees.....I averaged 34.8 on the last trip....32 pounds air in the tires
newprot5fan said:My gas mileage is pretty dismal.....21mpg and that isn;t driving it hard either (but that is mainly city).
So how long should I go before my next oil change? I just put synthetic in it (Mobil 1 5W30).
