Sway Bar linkage stud help.
Pro Fiz
Contributor
I was trying to take off the rear struts to put coil overs in, i got all the bolts off, then i saw the one bolt that holds the linkage of the sway bar to the strut, so i tryed to take it off, but i kept spinning the stud right behind it, it couldnt get it to stop spinning, i tryed gripping it with needle nose vice grips and a few other things, bu nothing worked, did this happen to anyone else... does anyone have any ideas on how i might be able to get it off? thanks alot
you talking about the endlinks??
if so there is a allen key hole in the end of the bolt. Use a open end wrench on the nut and put an allen key in the bolt. You also might want to used some wd40 or liquid wrench, they are a b**** to get off.
