I've cracked the MS3 ECU and will be releasing my access port software this *Friday, May 9th. Unprecedented gains. A bone stock MS3 put down 363hp @ 7000 RPMS. (oh yeah, the AP ups the redline to 7000rpms. I prob should have said that first) I've solved the throttle plate closure issue. My AP removes the throttle plate. It just got in the way anyhow!
Look at that torque!
Stock drivability is retained. Increases in fuel mileage of 10%. Also fixes smoking turbos and has a special rod reenforcement map.
WILL NOT VOID WARRANTY. That a promise backed by the Swampass name.
I guarantee this AP will land you the job you've always dreamed of, the woman (or man..hey! it's 2008!) you've always thought you've deserved. It covers embarrassing bald spots and gets red wine stains out of white carpet.
The unit is simple to use. Just plug it into your OBDII port and type in the wanted HP (I don't recommend going over 363 but hit 400 if you want, I promise it won't hurt!)
Look at that dyno!
AMAZING. Pricing starts @ $399.99 with free day before shipping (you'll actually get it before you order it)
before you say it's all BS, my product is about as real as the others.
Look at that dyno!
