The 2.0 is the same 2.0. The 2.0 uses the 2.3 aftermarket intakes and headers. my only question is if the mounting alows the clearance of the header that "Will" bolt up to exhaust port side of block. Unless he wants to trade in a loose then do what you can
	 2.0 is 148 without vvt....since we found someone with book you can ask if 2.0 has counter rotaing balance shafts as well...I beleve he's refering to the 3 6 and focus as in the Duratec 2.3 block...
