Sub and Amp ?
The easiest place will probably be behind the glove box. If you pull the box you should be able to run the power through the grommet and down the right side kick panels to the amp.
benzo said:
So this is what you would go with right....It's the 5th one down?
2 CHANNEL SPEAKER LEVEL TO PRE AMP LEVEL LINE OUTPUT ADAPTER
N-7V $34.50
yeah thats the one you want there is a 4 channel as well if you want... but a 2 channel will do the job if you aren't going to be amping the all 4 doors.
just a note a "0" awg will not fit you will have to drill your own hole... i drilled mine right next to the one that was there behind the glove box... it works out well... power down the passenger side, speaker cable and rca cable down the driver side...
just for you to know...I didn't like the sound of the stock head unit, so what I did was install a Rockford Fosgate 3sixty.2 processor. This allows the stock outputs to be into it, and then "fixed" so they are flat. Additional adjustments include 31 band EQ front, 27 band EQ rear (not that you'll use it), 15 band EQ sub, and full time alignment. It is all controlled using a Palm Pilot or other similar product shown to be supporting on their main website. From the processor, you hook up your amplifier(s) via RCA out. The results...to say the least, were astounding. The stock front speakers actually sound GREAT stock, and with a subwoofer, it was wonderful. Naturally, there are improvements one could make to the front end speakers, but it would be one of the last things I'd do.
In order of importance:
Wiring (power, ground, RCA, fresh speaker wire)
Full sound deadening. I used Raamat, and Ensolite. I recommend the same. 50sq. ft. raamat, and 4 yards ensolite dead minimum, to do the car correctly.
Amplifier(s) based on what you want to use.
Quality subwoofer(s) immediately after the amp(s). I used the spare tire well to fiberglass a box. Tough stuff!
Advanced processor, or very high-capability head unit. I didn't want to lose the stock integration and design, so the processor was an easy choice for me.
Front components, or DIY (make your own) setup. Like SEAS, Dayton, Lotus, Vifa, etc. Or, go the easy route and run JBL GTi, Eclipse Sc's, Pioneer PRS high end, Peerless, Rainbow, etc...the list is infinite.
After the front components I'd consider the system DONE, but if you must do rears, go for it.
Finally got everything installed. Had a forum buddy help me get it done right, solder and sealed the LoC in about an hour and a half. Ran the power line through the firewall behind the glove box like suggested.
Having the sub and amp really improves the stock H/U... sort of. Now I don't need to have the volume up around 30 to hear it on the highway with the windows down. Around 20 is loud enough for me. Defenately a good improvement and worth all the time and effort. Grateful I didn't have to bring it to a shop and pay for the install, just had to pay my friend in beers (drinks)
Thanks for all the replys and help!
Added some pics here. I may take the H/U out later today to show how everything was connected.
dear lord thats a big sub box... you probably could have mounted the amp to the back of the sub box and saved yourself some trunk room... or go sealed and save a bunch of trunk room... also i would suggest putting a layer of sound deadening on the front doors with just the stock set up it helped a bunch...
I havent mounted the amp to anything yet it is just sitting on the floor. I need to get a longer power line or move the amp under the front seat and get longer wires running from the amp to the sub. I salvaged all the wires from what was installed in my old 2dr car.
Euphorism said:
find the 4 wires on the wire harness that lead to the rear right pos, rear right neg, rear left pos, and rear left neg. those are the 4 wires you attatch to the harness on the LOC. you will lose the use of the rear speakers, but gain rca outputs for the use of an amplifer.
looks like there are 7 wires on that LOC, and i cant tell what they are from the pic, but you probably have a pos and neg for the LOC to hook up.. but i dont know what the 3rd is without seeing it in person.
So you guys are sayin you will loose the use of the rear speaker? Why? i am in the middle of piecing together my stereo now with on of these...I dont want to loose the use of my rear speakers....(pissed) Is there any way to fix that problem to where you can keep the rca output and keep the use of the speakers?
I have not done this, but I dont see why you would lose your rears. You are SPLICING the wire not cutting it off the rear.
As long as you just connect/splice/tab into the rears and run it to the rca, there should not be any problems.
Quote me if I am wrong plz
Now that sounds a hell of alot better to me it would be pointless to do this and not keep the rear speakers thats what i thought you were doing is just splicing or connecting to the rear speakers...to then give you an rca output!
Yup!!(inout)
Hey guys good luck with the install. I just bought an audiocontrol LC6 signal processor...CDT components up front, and coax in the back. I have a Phoenix Gold Xenon 100.4 powering those. I need help on sub and amp. 12 in small sealed box. Looking at TC9. Anyone heard of them. www.TCSOUNDS.com. Any suggestions?
WOAH....very important! Don't use the rear audio speaker signal for any kind of tap, unless you want some serious frequency response problems.
This is with regard to the 3 series cars, they have weird EQ on the rear speakers, and much less so on the fronts. Tap the FRONTS. Trust me!
Kosh said:
Who can tell me a good place to run power from the battery through the firewall? I have a 07 speed 3. This project is turning into quite a b**** and I almost wish I would have just paid for hi-fi buys to put it in...almost :)
Check out the info that is within this forum man! Chuyler1 wrote some stuff about it, as did I. The best place to put wire from 4 gauge and smaller, is behind the passenger side firewall heat shield, where the factory ECU wire harness has a grommet that connects to the engine compartment. Slit this grommet carefully, and poke your wire through. Then, tie up the power wire at the back of the firewall area (nice and tight fit, have fun), and run your connection through a fuse holder to the battery itself.
Read my install diary if you want info on the Speed 3, and what you can do with it, audio wise.
i have a 07 ms3 and just got my system installed. I had it done professionally because of many reasons. I had a 10w7 and alpine amp put in. I had it done at al+eds and they did an awesome job and it was only 90 some bucks with all the wires. The guy was very smart and has actually done a few regular 3's and he was a 100% set on splicing the rear speakers for the install and guarenteed me that there would be no issues and theyve done it this way millions of times. Maybe/probably not the for sure best way to do it, but it works great and is a lot easier. Now i just need advice on how to keep the box from moving
