SU motor mount HELP!
djza2u1
08 Black MS3
What comes with the su motor mount I recieved the mount but with not hardware. I think it is supposed to come with a new screw and nut. HELP me out
uh, call them and say you didn't get the mounting hardware?
Its just supposed to come with the mount and 1 washer.
You re-use the 2 stock bolts holding the stock rear MM in place.
F*** it, im going to get the Trz dog mount.
Ive heard of people complaining of the 2 piece design comming loose. And the TRZ has the nut welded on.
^^^^ yeah.
Ive never seen any problems with teh SU rear motor mount. How can it come lose . . . lol? Its a big piece of metal with 2 holes for bolts.
Ive had my motor mount on for a while and ive had no issues.
The SU rear motor mount is the exact same thing as the stock one . . . Just a bit bigger to hold everything in place better.
Um, its way beefier than stock, its two piece, and a SOLID urethane bushing instead of partial rubber. Other than that, yeah they're the same lol.
the su mount rocks. Don't give it up for the way vibey TRZ. Stick with it. Are you missing the 2 bols that hold the 2 pieces together? If you're JUST missing the bolt that goes into the one side for mounting, the stock bolt works fine you won't need the one that is supposed to come with it.
I only have the motor mount. It is bolted together, but i assume that they should have sent me a nut and bolt to replace the stock on, where the nut is welded on the stock mount.
oh yeah youre right on that. the nut part is welded on the stock mount. In that case yes they should have sent you another bolt and nut. The one Imine came with was black and had those locktite thing inside the nut I guess to hold it in better
Alright i stuck with the SU mount an recieved the nut and bolt today. I just installed it and (yeah the vibes should go away in 500-1000 miles) it is awsome. I can put the power down in 1st and 2nd.
GREAT PART!!!. (still wish i bought the trz dogbone)
At least you got your mount. I ordered mine from SU 2 months ago today and it hasn't even been shipped. Supposed to be done getting powder coated any day now and I'm supposed to get a call. Also ordered the black emblems a month ago and they haven't been shipped either. I like SU but they aren't on my good side right now.
Well I know they had the motor mounts on backorder for a while which probably is the reason.
Why did you order the black emblems !! You can do your own in 10 minutes and save 100 bucks !!!
